Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rally Racer needs 2.3L / 2.5L Help
Old 04-24-2013, 08:01 PM   #17
MainiaxMotorsports
Fan#: 84528
What I Drive: 2002 Rally-Spec SVT w/ 2.5L swap
Points 1,588, Level 22
Points: 1,588, Level: 22 Points: 1,588, Level: 22 Points: 1,588, Level: 22
Level Up 88% Completed
FF Reputation: 2 MainiaxMotorsports Good Standing Member
PLENUM for 2.5L Build
So, one of the ideas i wanted to make sure i addressed was the ability to goto a Cosworth Style plenum vs. stock intake. So, i reached out to a manufacturer, and searched the web.
1. Here is a pic of the 2.3L Head inlets i found on another forum
2. here is a pic of the 2.5L Head inlets below it (credit goes to the other forum poster)
3. The manufacturer says the bolts will line up, however, to get full advantage of the airflow capabilities of the plenum - a bit of machining can be used to open up the inlets on the plenum side
Here is a pic of the inlet side of the plenum style i will go with - my thought is to machine out some of that metal to insure it is matching the head side inlets in diameter.This way my TUNER has more air to work with.
Engine is supposed to be delivered friday !!!
MainiaxMotorsports is offline
