Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - LED Headlamp bulbs? (not HID)
Old 04-24-2013, 07:07 AM   #15
jcbbas
jcbbas's Avatar
Fan#: 90384
What I Drive: 2012 Ingot Silver Focus
FF Reputation: 1 jcbbas Good Standing Member
Originally Posted by bradshsi View Post
Ok I can maybe understand a bulb out error, although I'd be surprised if something pulling 22 watts would cause it. It would be very easy to confirm that by building a pretend LED bulb with a 25 watt 7 ohm resistor.
The flickering makes no sense. What would cause the bulb to flicker ?
From my understanding, the way the 12's and 13's work (and most newer cars) they send a small signal to the headlights to power them all, if the ECU detects the wrong power usage its sends a bulb out error and powers off the light. When using HID's and this LED kit that are rated below our normal wattage usage, after the bulb out error comes on and the power is killed to the headlight, there isn't enough power to keep the ballast powered on. In comes the use of resistors. They trick the ECU into thinking the bulb is using the full wattage. Which means no bulb out error as well as full power to light. Again thats my understanding so if I'm wrong feel free to correct me.
jcbbas is offline
