Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - turbo flange/manifold setup questions
Old 04-23-2013, 06:48 PM   #11
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
Level up: 59% Level up: 59% Level up: 59%
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
It depends but I would say 42lbs inyectors I have 60lbs but I'm aiming higher than u good luck google more info is the best way
Originally Posted by MrTerryToYou View Post
So I need bigger injectors? Stock zetec are 24# right. So would 30# svt injectors be enough or do I need bigger?
Sent from my SPH-L900 using FF Mobile
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
