Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - PCV or Not???
Thread: PCV or Not???
Old 04-21-2013, 07:38 PM   #1
HiPowerShooter
HiPowerShooter's Avatar
Fan#: 110017
What I Drive: 2000 Red Focus
FF Reputation: 1 HiPowerShooter Good Standing Member
PCV or Not???
Hi all...
My daughters 2000 "Hocus Pocus"(by Focus...I'm sure some of you "old" guys know what I'm talking about!)with the "Z-Tec" engine has a stumbling/MPG issue(low-mid 20's). She just bought it for nothing as it's got 240K on it. It actually is in good condition for it's age and mileage.
I started with the basics. Fuel/Air/Spark. I replaced the plugs which were old, and then tore into the "air" side of the equation.
I saw what I think is the PCV valve on the front of the engine block next to the exhaust manifold. The hose/metal tube runs under the cooling "block" to the back of the intake. I then read that the PCV is in the valve cover and has a hose to the air box(where I found the sponge-like filter disintegrated).
So....what did I fight with to remove? It sure LOOKS like/rattles like a PCV valve.
Also...as I removed it, I noticed the small 90 bent hose was split. Is this available seperately? It was pretty well cooked on and a REAL PITA to get off.
Thanks in advance!
HiPowerShooter is offline
