Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Brake Upgrade Question
Old 04-21-2013, 06:00 PM
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 25,145, Level 95
Points: 25,145, Level: 95 Points: 25,145, Level: 95 Points: 25,145, Level: 95
Level Up 80% Completed
Forum Activity 100%
FF Reputation: 81 felixthecat Excellent Standing Member
Your brakes are 10'' & the '05+ cars are equipped w/ 10.9'' brakes. To bolt those on you'll need the '05 only spindles= the '05+ brake calipers require the ears on the spindle to be spaced apart for the bigger caliper. In '05 Ford installed a bigger tapered ball joints. In '06 ford changed to a bigger strut diameter.You can still use your struts, using the '05 spindle. So it boils down to= You'll need to get the '05 only spindles, the '05+ ball joints & then you can bolt on the '05+ rotors & calipers. The '05+ brakes use a 10.9'' rotor & the svt's use a 300mm 11.8'' rotors w/ bigger calipers. Idk how many miles are on your car, but if you need to do ball joints, this swap makes sense. If I was doing it, I'd do the svt brake kit. Hit up Steve at Toulsey ford for M-2300-SVTF5, includes rotors/calipers & brake lines & caliper bolts. You could check to see if he has or can get M-2300-SVTF4 which is the same but comes w/ svt spindles, that'll bolt right up.
felixthecat is offline
