Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - New T-Belt Tensioner Failure... :(
Old 04-21-2013, 09:16 AM   #49
limeyrider
limeyrider's Avatar
Fan#: 35376
What I Drive: 2004 SVT, infrared, '72 Bonny 650
Points 713, Level 14
Points: 713, Level: 14 Points: 713, Level: 14 Points: 713, Level: 14
Level Up 13% Completed
Level up: 13% Level up: 13% Level up: 13%
FF Reputation: 7 limeyrider Good Standing Member
Originally Posted by iminhell View Post
guess the fact it's an 'auto tensioner' is lost on some ...
It is an auto *range* tensioner. Once it is set at the correct range, when installed correctly, tension is set by rotating the tension mechanism and an internal spring should keep between a min and max range. After it's set it should NEVER go outside of that range faster than the belt stretch would allow it to do.
What we're talking about is new tensioners going far beyond the max slack limit shortly after correct installation, thus not maintaining correct tension.
Raleigh NC - Home of deep fried sushi....
limeyrider is offline
