Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rear Suspension Trailing Arms (dog-bone) replacement.
Old 04-20-2013, 06:18 PM   #3
old school focus
old school focus's Avatar
Fan#: 64365
What I Drive: 01 zx3/ 03 svt jrsc/02 turbo svt
Points 27, Level 1
Points: 27, Level: 1 Points: 27, Level: 1 Points: 27, Level: 1
Level Up 54% Completed
FF Reputation: 1 old school focus Good Standing Member
Maybe you ment the main rear control arms. there is no strut. Just coil spring and shock. If you put a jack under the arm near the wheel and compress the suspension you can remove the lower shock bolt. you will need to disconnect sway if u have one. then unbolt outer bolt on arm near wheel. now you can lower jack and arm will drop allowing spring to come out. You can google replace rear control arm zx5 and prob find a video. Hope that helps and good luck.
old school focus is offline
