Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Car died while parking & now won't start
Old 04-19-2013, 10:03 PM   #11
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
Points 1,007, Level 17
Points: 1,007, Level: 17 Points: 1,007, Level: 17 Points: 1,007, Level: 17
Level Up 7% Completed
FF Reputation: 3 CotyM Good Standing Member
Originally Posted by rageclick View Post
Not sure how to check a relay. Which is the black box looking fuses I assume?
if you have a multimeter...
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
I think our cars have 5pin though instead of 4... but practically the same method none-the-less if you don't want to go replacing fuses left in right...
Also Eric's is a bit of a cluster *, if you have some soldering skills it may be best to solder up a small test bench to make it easier so your not trying to juggle wires, lol...
Also it is best to remove each fuse and inspect it, they may not look damaged until you get a closer look, sometimes they can even look fine but be bad, it's a good idea to have a cheap $2 fuse tester laying around! :)
2000 Ford Focus US Spec Zetec 5 speed "Blue Dragon"
2000 Renault Clio 1.4 DOHC 5speed "Snap Dragon"
Hatch Nation #32
CotyM is offline
