Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - few sohc build questions
Old 04-17-2013, 08:54 PM   #21
Donnyd21
Fan#: 109211
What I Drive: 2002
FF Reputation: 1 Donnyd21 Good Standing Member
Originally Posted by crxls View Post
Usually piston #i4 is the one that's messed up. Is there any reason I cant take piston #1, 2 or 3 out of another block and put it in cylinder 4 of the block I'm using?
I guess the last question for now is bearings. For the rod and crank bearings, is there just a standard size or will there be specific size on rod and crank that need to be matched for bearing size? I've built very technical Honda engines Where bearings needed measured and then I've built diesels Where you just throw in a standard size and torque to 300 million lbft and forget about it so I'm not sure what to expect here
You can use any # piston/rod in any # slot, just make sure the number on the rod and cap both face forward. Use sealed power STD size rod bearings and dont worry about the main bearings, my wifes car with 173k miles on it looked fine so I dont even check them anymore on rebuilds, the brunt end of the force and wear is on the top rod bearing.
PS - dont buy that kit from Import Performance, holy crap thats a rip off for those parts and it does not even include a head! Keep the SPI the way it was designed to be, a gas sipping eco box.
I HAVE GOOD USED OEM PISTON AND ROD ASSEMBLIES FOR ALL 2.0L SPI ENGINES (FOCUS, ESCORT AND TRACERS)!! PM ME.
Donnyd21 is offline
