Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SPI cylinder head gasket recommendation
Old 04-11-2013, 10:57 PM   #3
Fan#: 109856
What I Drive: Focus 2002, SPI, Gold
FF Reputation: 1 jiangfsh Good Standing Member
Thanks a lot, when I installing the head gasket I've go check if I need something to seal it, most comments donot recommend use any maker.
So for this spray only spray on the gasket not on the head or block, right ?
Originally Posted by Donnyd21 View Post
Any gasket you get will work, you have to be 120% certain that both the block AND head is clean and flat, any old gasket material left on the block or head will not allow a good seal. Also use the copper spray gasket on the head gasket before installing it
jiangfsh is offline
