Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 1.6 Zetec 2001
Thread: 1.6 Zetec 2001
Old 04-03-2013, 08:26 AM   #5
Fan#: 112812
What I Drive: 2001 Black
FF Reputation: 1 Quinn89 Good Standing Member
Originally Posted by sailor View Post
Our models have different engines on this side of the pond, but the cooling system is likely "similar".
Ours are self bleeding, with some small hoses (tiny plastic things) leading back to the reservoir bottle to purge any trapped air & bubbles that may develop.
Checking those for any damage (pinched, kinked), then removing & blowing back through them to check for obstruction (gently, like with your mouth) might find/cure your problem. (small obstruction would be blown out)
SOME air bubbles develop during normal operation, and when working right the system takes care of itself.
Hope this helps, Cheers!
Tried this. The small houses looked okay, and there was no visible damage to them. So unfortunately, I am still having the issue.
Quinn89 is offline
