Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Question about post-cat O2 sensor
Old 04-02-2013, 10:40 AM   #21
VillageT
Fan#: 97061
What I Drive: 2005 Silver ZX3
Points 335, Level 6
Points: 335, Level: 6 Points: 335, Level: 6 Points: 335, Level: 6
Level Up 70% Completed
FF Reputation: 1 VillageT Good Standing Member
I went through a similar issue with a Ztec. It turned out it was the hose to the PCV. I had also sprayed all the hoses but this one fails underneath were you can't see it and you can't spray in that area. We finally took it to a shop with "smoke test" equipment and they found it in a couple minutes. This equipment puts smoke into the engine and it is easy to see where the leaks are.
VillageT is offline
