Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - IROC turbo build continues
Old 04-02-2013, 10:06 AM   #279
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 53,713, Level 100
Points: 53,713, Level: 100 Points: 53,713, Level: 100 Points: 53,713, Level: 100
Forum Activity 6%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
Be safe yes, but you might burn out fuel pumps quicker. That's a lot of voltage your pump istrying to keep pumping up, common ways jim and chris and rudel did their set up was using the evap line for the feed and using stock fuel line under car for return. And if u use in tank return its safe to not go into boost when your at almost 1\4 tank. You can get fuel cut off. Focuzed I think relocated his pump in the middle andstuffed the tank with a lot of foam to help with that.
FF MODERATOR
RISE AGAIN EGGYOLK316 WHP 296 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
