Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - need help on 2001 ford focus se 2.0 16v tps
Old 04-01-2013, 12:19 AM   #5
amc49
Fan#: 96610
Points 6,705, Level 53
Points: 6,705, Level: 53 Points: 6,705, Level: 53 Points: 6,705, Level: 53
Level Up 78% Completed
Forum Activity 100%
Thinking better to stay just under one volt, I hear one volt can be the cutoff limit, past that PCM assumes car is in off-idle mode and will be starting to change up A/F ratios from the pure idle one.
'non adjustable tps sensor volt .9 1.1 v'
That means normally you don't adjust it, it goes in where the screws tighten it down at, the voltage will be correct if right part used. Of course that means if you don't have the correct TPS (ATX vs. MTX) you will have a problem, they do not go in in the same position and voltage will be wrong if using the wrong part.
amc49 is offline
