Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Timing tool stuck!
Old 04-01-2013, 12:12 AM   #10
Chris_HT
Chris_HT's Avatar
Fan#: 86229
What I Drive: Blue SVT 2002
Points 1,672, Level 23
Points: 1,672, Level: 23 Points: 1,672, Level: 23 Points: 1,672, Level: 23
Level Up 72% Completed
FF Reputation: 5 Chris_HT Good Standing Member
Originally Posted by Deus Machina View Post
The comment I had read did say you can use the pin to lock the cam in place to break the crank gear loose.
Well, bad instructions or maybe you didn't read something well. I don't know.
What I do know is that you don't need to loose crank gear for timing belt job. And if you were trying to replace crank pulley then you do it by attaching long ratchet to the bolt and turning the engine starter (in short, if you didn't do that before you better read into detailed procedure).
Let us know how it went with releasing the stuck pin.
Blue SVT 2002
Our Lady of blessed acceleration
But.... why read facts and investigate a claim when it supports your ideology?
...that should be written as 'The First Law of Internet Forums'
Chris_HT is offline
