Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Installed Sportlines car, not sitting level!!!!
Old 03-31-2013, 07:22 PM   #7
Tyler T
Tyler T's Avatar
Fan#: 42066
What I Drive: two '02 SVT's
Points 1,197, Level 18
Points: 1,197, Level: 18 Points: 1,197, Level: 18 Points: 1,197, Level: 18
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 5%
FF Reputation: 2 Tyler T Good Standing Member
Did you remove both rear springs and compare them? Since they're used there could be an irregularity with one of them. But it is unlikely.
Since you used the rubber isolator on the upper spring perch I'd recommend double checking that the top of the spring is seated properly in the isolator. I'm sure you noticed that there is a notch for the end of the coil to fit into.
Also, roughly what is the overall spring length? Some sport springs are short enough that at full droop they can fall out of place and then when the car settles back on its wheels the spring will be out of place. Something along these lines could be your problem.
Tyler T is offline
