Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - experience Needed transmission, throttle body, troubles? (This is long)
Old 03-30-2013, 06:18 PM   #4
Alptbird
Alptbird's Avatar
Fan#: 109943
What I Drive: 2008 focus sedan
Points 679, Level 13
Points: 679, Level: 13 Points: 679, Level: 13 Points: 679, Level: 13
Level Up 58% Completed
Level up: 58% Level up: 58% Level up: 58%
FF Reputation: 1 Alptbird Good Standing Member
The initial problem was it would down shift to second when slowing to make a turn. That problem is fixed.
Edit:
I tried the battery reset. Checked fluid level. Removed 8oz and while running and warm the level was perfect. Still no dice. No codes. I noticed though when it was doing the lunging thing the engine RPMs jumped with the lurch. Not sure if that means something or not. Not to mention you could hear it with the open element air filter. Also noticed the engine is slower to rev now. Even in park or neutral. It still does but it is not as responsive as I am used to.
Alptbird is offline
