Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Installed Sportlines car, not sitting level!!!!
Old 03-30-2013, 12:16 AM   #1
RallyWerks
RallyWerks's Avatar
Fan#: 54867
What I Drive: 2003 2.3 Twilight Blue ZX3
Points 3,036, Level 33
Points: 3,036, Level: 33 Points: 3,036, Level: 33 Points: 3,036, Level: 33
Level Up 91% Completed
FF Reputation: 1 RallyWerks Good Standing Member
Buy-Sell-Trade Rating: (4)
So I installed a set of used Eibach Sportlines on my SVT. All was just fine until I noticed that the passenger rear sits about a half inch or more higher that the opposing side. The fronts seem fine and look the same.
I checked to make sure I installed them right side up.
I took the spring out tonight and then reinstalled it, making sure I did everything perfect.
It still sits the same, noticeably higher than the other side.
The only thing I can think of now is to take take the other spring out and swap sides to see if its a spring issue.
Also, I DID reuse the factory rubber piece that goes on the top of the spring.
So if this has happened to anyone else or if anyone has any suggestions as to how I can make adjustments, your help would be greatly appreciated.
Thanks guys,
Chris
It's stock, don't worry about it.
SoCal Crew#13
RallyWerks is offline
