Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Dome lights
Thread: Dome lights
Old 03-28-2013, 06:02 PM   #70
FocusFoxUS
FocusFoxUS's Avatar
Fan#: 111025
What I Drive: 2013 Oxford White SE HB
Points 133, Level 2
Points: 133, Level: 2 Points: 133, Level: 2 Points: 133, Level: 2
Level Up 66% Completed
FF Reputation: 1 FocusFoxUS Good Standing Member
Originally Posted by supernova1 View Post
Here is how it works for me (my car uses two-stage door unlock):
After your car sits closed for several hours
1. Press "Open" on the key fob once - the driver door opens, but dome light is OFF;
2. Press "Close" on the key fob once - the driver door closes;
3. Press "Open" on the key fob once - the driver door opens and the dome light is ON.
I believe that it is a "stealth" feature in case you want to open your car, but do not want to attract attention to it (you figure the case for this), so it has a mode when the dome light is OFF on the first "Open" click.
It also seems to me that this feature has a timer - if you close your car doors and then after several minutes press "Open" again, the dome light will light up. Only after the car sits closed for several hours (can not get the exact time) the dome light is OFF on the first "Open" click.
I can not still figure out the dome light switch with "OFF" sign - to me it just toggles through two states (switch backlight ON/OFF), but does not do anything other than this.
Kudos to Supernova1 for figuring this out. You'd think it could be explained in the owner's manual easily enough. I was going crazy trying to figure out when and why it turned on or not.
FocusFoxUS is offline
