Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Need help!
Thread: Need help!
Old 03-28-2013, 05:01 AM   #20
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
What I Drive: 5.9L Grand Cherokee ZJ
Points 24,482, Level 95
Points: 24,482, Level: 95 Points: 24,482, Level: 95 Points: 24,482, Level: 95
Level Up 14% Completed
Level up: 14% Level up: 14% Level up: 14%
FF Reputation: 76 mikebontoft Excellent Standing Member
Buy-Sell-Trade Rating: (3)
Bad rings will not cause oil to pool up above the spark plugs. When you removed the plug, the oil filled into the cylinder. It's just the valve cover gasket.
The lifters are a solid bucket type, so there is no adjustment available. I'd recommend an oil change and the use a of a good filter. Some of the crappy ones can inhibit pressure and cause upper end noise.
Since there is very little to no vacuum on acceleration, the noise is not a vacuum leak.
Your fuel pump sounds like it could be a little louder than it should be, however you can faintly feel/hear it. I would keep an eye on it anyway. Some pumps get pretty loud when they're about to fail.
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parted) | '75 BMW 2002 "Carby" (racecar) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (daily).
Moderating
and
mikebontoft is offline
