Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Excess Front-end Vibration
Old 03-27-2013, 12:54 PM   #15
bile0026
bile0026's Avatar
Fan#: 97349
What I Drive: 2009 Amber Gold Metalic Focus
Points 410, Level 8
Points: 410, Level: 8 Points: 410, Level: 8 Points: 410, Level: 8
Level Up 20% Completed
FF Reputation: 7 bile0026 Good Standing Member
Again, I would say its probably that axle and it has most likely taken out the bearing by now. I would start there with replacing the axle and bearing.
Groaning brakes can be a number of things including glazed pads (from overheating), improperly broken in brakes, uneven mating surfaces (grooved rotors or pads), and glazed/overheated/heatchecked rotors. Noise in brakes is almost always caused by a vibration. Usually the higher pitched the groan or squeal the faster the vibration. For example if your pads are slipping and grabbing they can groan because of the "vibration" from slipping and grabbing.
2009 Ford Focus Sedan SE--Amber Gold Metallic--FS Cool-flo intake, 17" Black Kazera Rims with Potenza S-04PP, Custom 2.5" Exhaust.
bile0026 is offline
