Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2008-2011 Projector Retrofit Guide: Morimoto Mini H1
Old 03-27-2013, 07:21 AM   #40
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
Points 4,931, Level 44
Points: 4,931, Level: 44 Points: 4,931, Level: 44 Points: 4,931, Level: 44
Level Up 91% Completed
FF Reputation: 5 DarderSauce Good Standing Member
Originally Posted by A7xschecter6661 View Post
By the way, the metalcast paint will only work over chrome or the metalcast base coat.
Are you painting it with metal cast and using engine enamel clear over it or what?
Thier .PDF on application tips for metalcast says:
Over Bare Plastic
- Desgrease
- Scuff
- Degrease
- Apply 1-2 light coats of CP199 Adhesion Promoter
Doesn't mention anything about a chrome or metalcast base coat.
I am painting the Turn Signal and light bulb chrome blue (metalcast), the iris shrouds will be gloss black (enamel). Metalcast doesn't have a black and their smoke color looked a bit like graphite on the net from the pics I saw. That is why I am using the engine enamel paint.
As for duplicolors response, I think you're right, they probably thought I was painting the lenses.
If you can't wear it out, burn it off
DarderSauce is offline
