Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Question for Focus owners with Sync?
Old 03-27-2013, 12:45 AM   #13
asting
Fan#: 98342
What I Drive: 2012, Tux Blk Met Focus 5d Sport
Points 536, Level 10
Points: 536, Level: 10 Points: 536, Level: 10 Points: 536, Level: 10
Level Up 72% Completed
FF Reputation: 1 asting Good Standing Member
How bad is it? I've seen on these forums that people put dynamat under the microphone and it helps a bit. I plan on doing the entire car, including the roof so supposedly it should improve. What speed is the road noise at?
Originally Posted by riparke View Post
What version of sync? I had the same problem with 3.1.1c, yesterday dealer upgraded to 3.1.4c and the mic is a lot better. you can check your version at http://www.ford.com/syncmyride/ with a usb stick. This is sync only not MyfordTouch.
How did you download that version? Mine only shows 3.1.1c and says it is up to date.
edit: apparently it's dealer only.
asting is offline
