Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to: Outer dash vent swap (SE to ST and ST to SE)
Old 03-26-2013, 11:20 PM   #16
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
Points 2,541, Level 30
Points: 2,541, Level: 30 Points: 2,541, Level: 30 Points: 2,541, Level: 30
Level Up 61% Completed
FF Reputation: 8 I Bleed Ford Blue Good Standing Member
Twenty, got a question for you. When you swapped the vents from your buddy's ST, you said the '13 headlight switch plugged right in. Did the 13 switch have an extra plug socket for the trunk release, or was it identical to the 12 switches from the back? I'm thinking about getting a 13 switch and trying to get it working in my 12. Not having a trunk release button on the inside of the car irks me to no end. My fusion had one, the escape has one, even the 08 fusion SE had one.
13 Blue Flame F150 FX4 402A on 20's loaded
13 Frosted Glass Escape Ti 401A loaded
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
