Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - need help on 2001 ford focus se 2.0 16v tps
Old 03-25-2013, 05:06 PM   #2
amc49
Fan#: 96610
Points 6,436, Level 52
Points: 6,436, Level: 52 Points: 6,436, Level: 52 Points: 6,436, Level: 52
Level Up 44% Completed
Forum Activity 100%
No exact number, thinking the range from .98 idle to 4.84 wide open, idle must be slightly under one volt. The PCM makes up for any slight variance, if TPS put in correctly it should be right. PCM recreates the absolute start and stop volts if switch in right. More important is measuring volts through the swing and no drops or jumps there at all, only smooth increase or decrease of voltage. Look close at idle and just off idle, the switch contacts spend most of the time around there and vibration wears the resistor track more.
Meaning the pure idle setting could vary from switch to switch and still run fine.
amc49 is offline
