Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SuperFocus
Thread: SuperFocus
Old 03-25-2013, 10:34 AM   #4
DarwinSays
DarwinSays's Avatar
Fan#: 35941
What I Drive: 2004 SVT Silver / EAP / CWP
Points 1,382, Level 20
Points: 1,382, Level: 20 Points: 1,382, Level: 20 Points: 1,382, Level: 20
Level Up 82% Completed
FF Reputation: 3 DarwinSays Good Standing Member
An engine swap would be the first step towards fail. The extra weight in the front from a bigger engine would not only compromise handling, but make spin-out on deceleration more likely.
The '03-04 Cobras weighed around 3650lbs and were pushing about 390hp at the crank. that equates to about 106.5hp/ton.
To achieve that ratio in a 2650 lb focus, you would need about 290hp, which isn't that far-fetched a goal for a well-built Zetec and would actually give you a tiny bit of pull on the Cobra until you're on longer straights (where the Cobra will still have the higher top speed).
Granted, getting that much power out of the motor and onto the pavement will cost you a solid chunk of change, but that's pretty much what you're looking at.
#include 'brain.h'
DarwinSays is offline
