Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - road trip question
Old 03-24-2013, 01:36 PM   #8
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 24,774, Level 95
Points: 24,774, Level: 95 Points: 24,774, Level: 95 Points: 24,774, Level: 95
Level Up 43% Completed
Forum Activity 100%
FF Reputation: 80 felixthecat Excellent Standing Member
Originally Posted by Baldurs390 View Post
thanks for the answers... the main reason was because i was reading a how to ona f2 header and the poster said tht the header was very close to the alternator and i didnt wanna melt it for driving for 8-12 hours straight... long drive straight was 22 hours from florida to ri
My 23 mani/cat had a 3 piece heat shield. I carefully undid the tabs that held it together & used the alternator heat shield, w/ a couple black tie wraps holding the top side up. Also make sure the speed senser wire & the o2 senser is tied up away from the header. One more thing is make sure to use a dogbone vf engineering or similar, for if not the bottom of the header could hit the cradle or very close, when the motor rolls w/ the stock dogbone.You might have to oblong the stock bracket that goes from the motor to the header, thats what I ended up doing. I hope that helps you= Baldurs390.
felixthecat is offline
