Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Zurich Preferred Warranty
Old 03-23-2013, 02:07 PM   #1
GMconvert
GMconvert's Avatar
Fan#: 101277
What I Drive: 2010 Sangria Red Metallic Focus SES
Points 303, Level 6
Points: 303, Level: 6 Points: 303, Level: 6 Points: 303, Level: 6
Level Up 6% Completed
FF Reputation: 2 GMconvert Good Standing Member
Just went through PA inspection with the '10 Focus SES Sedan, service tech suggested replacing rear wheel cylinders as they were seeping brake fluid.
My Zurich Preferred Warranty covers the following:
7. Brakes: Master cylinder, vacuum assist booster, hydro-boost and accumulator, disc calipers, wheel cylinders, flexible hydraulic lines and fittings...and brake fluid when it is required in connection with the repair or replacement of a covered part.
My contract also states that I must have my vehicle checked and serviced in accordance with the manufacturer's recommendations outline in Owner's Manual and failure to do so may result in denial of coverage.
My question is this: How stringent are they with following Owner's Manual service intervals? I've had the vehicle in to the dealer for regular oil changes and tire rotations, alignment as needed, etc. Is this enough to show I've maintained the vehicle (with receipts for all service) or am I SOL for not following service recommendations to the "T"?
GMconvert is offline
