Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - custom power steering lines?
Old 03-23-2013, 12:30 PM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,393, Level 94
Points: 23,393, Level: 94 Points: 23,393, Level: 94 Points: 23,393, Level: 94
Level Up 5% Completed
Level up: 5% Level up: 5% Level up: 5%
Forum Activity 14%
Activity: 14% Activity: 14% Activity: 14%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Originally Posted by S0C0nFused View Post
Ummm! Think this through a bit. Power steering = hydraulics. Means you have a 'high' pressure side and a low pressure side. The 'cooler' would have to be on the low pressure side, where it would do nothing (other than impede flow back to the pump). The 'high' pressure side fittings need to be formed pipe (you found that) OR high pressure hydraulic hose WITH proper end fittings JOINED with a multi-ton 'band' gizmo. Recommend you don't purchase any hose or what not until you find a shop that has the machines to make small diameter hydraulic hoses as they prob won't guarantee the piece unless they use there own stuff. Low pressure side you can just use screw type band clamps.
Luck!
How does an engine oil cooler work?
How does a transmission oil cooler work?
How does a engine coolant radiator work?
ALL are on the return side.
He knows the cooler is on the low side and never said he wanted to route the high side through it ...
iminhell is offline
