Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - custom power steering lines?
Old 03-22-2013, 02:16 PM   #5
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,348, Level 72
Points: 12,348, Level: 72 Points: 12,348, Level: 72 Points: 12,348, Level: 72
Level Up 75% Completed
FF Reputation: 77 S0C0nFused Excellent Standing Member
Originally Posted by drunkinmonkey View Post
im rplacing with a new rack and a new pump but want to make custom lines and have them going to an oil cooler in between my rad and intercooler
Ummm! Think this through a bit. Power steering = hydraulics. Means you have a 'high' pressure side and a low pressure side. The 'cooler' would have to be on the low pressure side, where it would do nothing (other than impede flow back to the pump). The 'high' pressure side fittings need to be formed pipe (you found that) OR high pressure hydraulic hose WITH proper end fittings JOINED with a multi-ton 'band' gizmo. Recommend you don't purchase any hose or what not until you find a shop that has the machines to make small diameter hydraulic hoses as they prob won't guarantee the piece unless they use there own stuff. Low pressure side you can just use screw type band clamps.
Luck!
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
