Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Exhaust Overhaul Questions for 2001 ZX3
Old 03-20-2013, 02:20 PM   #7
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 13,880, Level 76
Points: 13,880, Level: 76 Points: 13,880, Level: 76 Points: 13,880, Level: 76
Level Up 58% Completed
Level up: 58% Level up: 58% Level up: 58%
Forum Activity 42%
Activity: 42% Activity: 42% Activity: 42%
Thanks! The Tick is coming along... doing body work right now while waiting on availability of parts and funds to buy parts.
The SVT header requires you to convert the rest of the exhaust that is not replaced by a CAT back.
If you go with a SVT header you need: SVT header, SVT CAT, SVT Flex, SVT Oil Dipstick Tube, SVT PS Line (or bend your current line), EGR block off plate w/tune or EGR bung welded in.
a Tune is recommended in general with this because you can lean out at WOT. not sure any one had damaged the motor but you would lose power.
I believe the stock SVT CAT is higher flow then Zetec stock CAT. Your gains from this conversion is not from the change of the cat rather the change to a full length 4-2-1 header that the SVT is.
Magus2727 is online now
