Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Eibach sportline & sways install suggestions?
Old 03-20-2013, 09:00 AM   #14
Deeprecon1
Fan#: 109780
What I Drive: 2013 silver se 5 speed & 04 F250SD
FF Reputation: 1 Deeprecon1 Good Standing Member
That is a hard call, I have not driven a focus with Steeds. I would suggest you get a set of struts and shocks before you take on the swap. DONT USE STOCK
the foci will handle much better w/ sways and springs. I really need to get off my butt and post pics showing how the car stands with stock 17s. I have no wheel gap and have never rubbed.
Compression rate on the stock strut is not set up for handling the rough Cali roads.
Rebound is ok ... but you will have a little NOT BAD bounce after mild bumps
The sways ... make a big difference in roll. Very noticeable when cornering hard on rough surface. The foci likes to rail corners
The big question is are you going to self install ?
you will need METRIC sockets, wrenches, Allen keys .. big cheater bar.
Since your back east soak the bolts the night before "liquid wrench"
Originally Posted by RedVAhb757 View Post
If you had the choice to do it over again would you have gone with the steeds springs & bars? I'm contemplating this same kit really hard. I do know the ride in my focus is rougher now than when I bought it but I accredit that to the factory continentals having 42k miles on them and 4/32 tread left.
13 Silver 5spd MT
Deeprecon1 is offline
