Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Head Bolts - Tighten a bit more?
Old 03-18-2013, 08:41 PM   #5
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Ford actually doesn't state a value or minimum for compression readings. Instead they only state that compression measured between cylinders should be within 25%. Unless that's been changed and published somewhere.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
