Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Bung size for an EGR weld-on a SVT header?
Old 03-18-2013, 07:36 PM   #16
Trev FF
Trev FF's Avatar
Fan#: 99052
What I Drive: 2000 focus ZX3, 2003 Svt
Points 2,800, Level 32
Points: 2,800, Level: 32 Points: 2,800, Level: 32 Points: 2,800, Level: 32
Level Up 34% Completed
FF Reputation: 1 Trev FF Good Standing Member
Originally Posted by Magus2727 View Post
Would look like it. Its for the same machine, would not surprise me of its just a rebranded Parker part. Have already fitted it up and mocked everything up. It fits and the flair is perfect. Last bit I needs to do is put the hole in the header, and then shave and cut the other end of the fitting as needed. Once I do that it off to the welder.
what bung did u end up using, im having to do the same. wanted to do a egr delete but that would throw a code and i would have to tune.
2003 SVT focus
K&N typhoon, Ceramic Ford racing header, Orp, borla catback, Toms tune, Clutchmasters aluminum flywheel and stg 1 clutch, poly engine mounts, eibach sportline kit drilled slotted rotors, potenza re760s
Trev FF is offline
