Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Focus SE Transmission Grinding
Old 03-18-2013, 06:15 PM   #290
Strix
Fan#: 85696
What I Drive: Not a Ford
Points 572, Level 11
Points: 572, Level: 11 Points: 572, Level: 11 Points: 572, Level: 11
Level Up 44% Completed
FF Reputation: 1 Strix Good Standing Member
Originally Posted by Sprint View Post
The customer service rep here can also help you if you get push back.
Not that I've seen. Unless by 'help' you mean telling you that there's nothing they can do if the dealership says it's normal.
A grinding transmission is not normal - it is the sound of your transmission being worn out prematurely. You don't need to be an expert to be sure of this so don't let the "experts" try to pull the wool over.
It's not 'worn out prematurely' if it makes it to the end of the warranty period. That's all that matters to Ford.
Good luck.
You'll need it.
Strix is offline
