Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Replace master cylinder clutch
Old 03-17-2013, 01:08 PM   #126
LugNut
LugNut's Avatar
Fan#: 92146
What I Drive: 2001 White Sedan
Points 2,043, Level 27
Points: 2,043, Level: 27 Points: 2,043, Level: 27 Points: 2,043, Level: 27
Level Up 29% Completed
FF Reputation: 1 LugNut Good Standing Member
Exclamation Check that mounting bolt while in there!
Wierd related news:
A month or so later, the huge clutch pedal bolt (the one the pedal swings on) snapped! I hadn't touched it at all; if I had removed it I would have likely seen wear and definitely at least greased it. The mechanic who fixed it said Ford no longer stocked the part, so he had to fabricate it.
Anyone else had this bolt problem? I haven't search the site.
LugNut
Fixed Up a white 2001 P-code SE Sedan
including rebuilding the SPI (see my threads)
LugNut is offline
