Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Looking for 12V Switched Power Behind Radio
Old 03-16-2013, 12:01 PM   #2
mp223
Fan#: 104161
What I Drive: 2012 Focus SEL
Points 266, Level 5
Points: 266, Level: 5 Points: 266, Level: 5 Points: 266, Level: 5
Level Up 32% Completed
FF Reputation: 0 mp223 Newbie
Does yours come radio with SYNC/USB support? If so, look behind the radio for the Accessory Protocol Interface Module (APIM). There is a +5v violet/grey wire coming out of pin 8. This is directed to the USB port in the glove box or center console, and you can tap into that without having to use an auxiliary 12v-5v converter. It is not a true ACC wire, in that it will also be powered on when the radio is on without a key, but will also shutdown automatically, with the radio, after a predetermined time. I would use that wire if possible, rather than adding an additional transformer.
mp223 is offline
