Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Adding factory fog light switch on SE
Old 03-13-2013, 10:55 PM   #13
Wasney
Wasney's Avatar
Fan#: 109571
What I Drive: 5SPD 2013 Focus SE
Points 279, Level 5
Points: 279, Level: 5 Points: 279, Level: 5 Points: 279, Level: 5
Level Up 58% Completed
Level up: 58% Level up: 58% Level up: 58%
FF Reputation: 2 Wasney Good Standing Member
Originally Posted by Monkeygrits View Post
Mines been hooked up with an aftermarket switch for a while now. Still working great.
Adding fog lamps?
I see in your posts you got the bling kit and paired it with a wiring kit and new switch. The bling kit says it comes with all wires and a switch. Why didn't you use the included wiring? Was it not compatible? I understand using the other switch, it looks a lot cleaner.
I am trying to figure out all what to buy for this route. I would prefer if it cam on automatically using relays that come on with the headlights on, with the option to hit a off whenever as well, but that looks like a lot of extra work. May just go the same route as you, having it on/off with a switch only (unless I am mixing your post with someone else s, and you did something else).
Wasney is offline
