Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - KSport Coilover Issues
Old 03-12-2013, 11:02 PM   #15
RPMisChris
RPMisChris's Avatar
Fan#: 76276
What I Drive: 07 svt 2.3 swap thing
Points 6,066, Level 50
Points: 6,066, Level: 50 Points: 6,066, Level: 50 Points: 6,066, Level: 50
Level Up 58% Completed
Level up: 58% Level up: 58% Level up: 58%
FF Reputation: 1 RPMisChris Good Standing Member
Buy-Sell-Trade Rating: (16)
Originally Posted by ksport View Post
I hope you don't mind if we comment on this thread to possibly explain our side of the situation.
Initially we received an email from our dealer TH saying a customer had a coilover set that had a nut that we welded on, i stated that is not possible an we needed pictures. After receiving pictures i confirmed the nut was not welded and looked in fine condition and we instructed them to have customer call us directly. I received a phone call from a person regarding this situation. I know OP says it was the shop, but she stated she was your wife and not a repair shop. Yes i did state the nut should not be removed to her as i was confusing this application with the Mazda 3, but with over 1000 products developed its really really difficult to remember the particulars of each one off the top of my head, hence the reason we requested the call back before we came to any conclusion as to what happened here.
Regardless we are not sure why the shock was so damaged removing a nut. The nuts do not have locktite (we would love to speak to the mechanic that stated this as there is no way this is possible since we do not even have locktite on the assembly line), they are nylon locking nuts, which are designed so they do not back off while on the vehicle, a very very standard nut. This is a non-issue when removed with an impact.
If there is every any defect of cource we would take care of it, we do not sell over 5000 coilover systems per year by having poor customer service and screwing over people. But when we hear the nut is welded, than it was cross threaded, than there is locktite, all of which we know is not possible we tend to think possibly there was installer error the mechanic is trying to push blame on us. Hence the reason we requested to speak to the shop you said installed them, so we can try to understand how this was damaged. These nuts are designed to go on and off, over and over, but an impact is needed set to 45-50lbs. of torque, and its not possible to cross thread this nut on the shaft due to thread pitch and damage shown.
Really??? My wife connected you on the phone with the suspension shop. The mechanic told you that it came in cross threaded and loctite was on that nut before they removed the nut (this alone satisfies your warranty; was never installed on the vehicle and came in damaged from the factory). This shop has done suspension since 1987 and has all the right tools and knows the install procedures very well; in fact better than you as they had to explicitly explain to you how to install your own suspension because you acted as if you had no knowledge of your own product. I have written documentation of all communications via email, phone (with my wife and with the mechanic at the shop) and photo evidence of the entire situation.
Despite all of this you continue to give me the run around asking the same questions over and over again as if you are stalling for some reason. The mechanic said you are probably stalling because you will lose a commission if you have to give a warranty part out. If this is the truth, which I dont want to believe, this makes KSport and you highly unreputable.
You are also refusing to accept responsibility for the situation even after I have provided you with ALL of the information that you have asked of me. I believe you are just coming on this forum to save face with the focus community. This is absolutely ridiculous and I do not appreciate your customer service towards me, my wife, or the mechanics at the suspension shop.
It is to the point that if you do not honor your warranty that I will be forced to go to small claims court for not only the shock but for the time and money that I have lost in this entire process. Keep in mind that it will cost you more to fight me in court than it will to just honor your warranty.
RPMisChris is offline
