Which harness did you require? Standalone can a bus or moto control relay? Also besides the standard plug in play items did you have to run and wires to the battery? And does the headlights have to come out to do this install?
I bought mine from another member on here. It came with the morimoto heavy duty relay harness. and you connect it to the battery and a ground. And with and hid install on second gens you will have to remove the passenger side headlight to install its light. The drivers side does not have to be removed though.
Our cars do not require a special harness. I started out with the standard h13 relay but mine rusted out so i have replaced it with the morimoto black box.
I am running 50 watts and have never been given any trouble from the fuzz. You are taking a small light source and spreading it out over a large distance. You wont be as happy with the lights if you go 35w.
But you need projectors! This system rewires the lights to make the highbeams control a solenoid for the projectors. Sticking a xenon bulb in your stock housing is dangerous to everyone around you plus when it rains, snows, or you are driving in fog there will be so much kickback.
Unfortunately both lights must come out unless you have a cold air intake to install the harness. It can be installed from eother side. It just plugs into where the old bulb used to be. Depending on how long the power lead is you will most likely need to plug it into the driver side. Secure everything down because the ballasts and controller do not like the vibrations -may shorten the lifespan if you do not.
If you plan on retrofiting later i would wait on this unless you have some form of projector like eagle eyes but be mindful that setup uses a h9 bulb i think. If youre using the stock housings it would be better to find a 50/65watt halogen bulb.
35 watt. MH1 projectors are to small for 55 watts. 55 watts will ruin the chrome coating on the projector bowls after time. TRS does not recommend 55 watts in the MH1s because of this.
I would just do the stage 3 kit with the projectors. Might as will buy it all and do it right the first time.
Just Don't have the balls to do it to my only set of lights. Screw up = im royally [][][][][][][][][][][][]. Probally buy eagle then attempt it.
Related Threads
Focus Fanatics Forum
5.8M posts
189.1K members
Since 2003
