Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Bling Lights Fog light install
Old 03-11-2013, 01:12 PM   #7
Matasickle
Matasickle's Avatar
Fan#: 77627
What I Drive: MK3 SGM SE
Points 2,726, Level 31
Points: 2,726, Level: 31 Points: 2,726, Level: 31 Points: 2,726, Level: 31
Level Up 84% Completed
Level up: 84% Level up: 84% Level up: 84%
FF Reputation: 2 Matasickle Good Standing Member
Originally Posted by Hiwayracer View Post
Thanks.
How did you wire the switch ?
The kit came with all the wiring necessary.. all you need to do is plug it all together, run the wires as you please, and connect the + (red) and ground (black) to your car. (See pics below)
Originally Posted by thejordan View Post
This is amazing.
Couple questions...
- How is the switch done? (Pic?) Did you snake it into your dash? (where?)
- Can you leave the switch set to "on" and will it turn off when you turn the car off?
- Can you replace the blue accent bulb with a yellow one, if so, do you know the bulb part #?
1. Switch came with the kit. I did not want to cut into any of my dash to I jerry-rigged it where the diagnostic computer plugs in (looks awful.. but is hidden so no one will know.. Shhhhh!)
2. You can leave the switch to one and it will stay on with the ignition off /keys out (because it's hard wired to the battery)
3. I am not sure about replacing the bulb to yellow.. I would assume you can.. but I didn't really look into.. send Andrew an e-mail about it and tell him Y3VT3P sent you (maybe he'll hook you up with a better deal).
Also, I'll pay you to make me a set of brackets :D
Oh yeah?
How much?
PICTURES!
The wiring:
Where the switch resides:
I know it's ugly.. I will probably make a nice bracket for it at some point..
Matasickle is offline
