Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Does your vent selector stick? Have you broken the cables? Read on,
Old 03-11-2013, 09:15 AM   #6
Fan#: 111199
What I Drive: 07 Focus SE sedan Deep Torredor Red
FF Reputation: 1 fozziebear Good Standing Member
My 07 has a problem with sticking too.What I found is not in the cables or blower housing but the bled door it self.The rubber seal Ford uses gets sticky over time and doesn't release from the housing where it makes contact.If the center vent and duct is removed you can just get your hand to the top of the blend door and you'll feel it stick.As a short term fix spray some silicone spray on the blend door and work it limit to limit several times.This will last several months then it will need to be done again.
fozziebear is offline
