Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Hi and low slop for modified injectors
Old 03-09-2013, 01:31 PM   #9
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT Turbocharged
Points 67,003, Level 100
Points: 67,003, Level: 100 Points: 67,003, Level: 100 Points: 67,003, Level: 100
Forum Activity 100%
FF Reputation: 158 1turbofocus Excellent Standing Member 1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (29)
Originally Posted by paulg127 View Post
High slope is calculated from injector flow, ( lb flow/3600 ) to get in the ballpark, but the 58lb rating does not seem too accurate. The low slope and breakpoints are very hardware specific, but you can use the adaptive fuel terms of the, what is commonly called short term fuel trim, and the long term fuel trim to dial it in.
Typically the idle adaptive (long term fuel trim, lowest air mass) will show if the low slope may not be correct. If the other (higher air mass) adaptive values are close to nominal, most likely the high slope is pretty close, leaving the low slope to correct the idle adaptive cell, provided you do not have an air leak.
If you don't have either the MAF transfer function or the injectors accurately characterized, you really have no way of knowing which, if either is correct.
I'm sure someone has a 3" maf transfer function out there somewhere....
You should never use long turm fuel trim for tuning anything and never use short turm fuel trim or either for setting the high or low slopes
LTFT should be turned off in my opinion and STFT1 should be adjusted in the MTF , what about WOT and the high slope ? what about when he changes to blowthrough , adds a MAFia , you can throw out any MTF any one can give you and and injector settings on paper , then what does he do ?
Why does everyone approach tuning engines the hard way
Tom
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance!
Customer Support
AIM: hpdyno
Email:
Phone: 704-249-3745
Site:
Elder 1turbofocus
1turbofocus is offline
