Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2005 ST 2.3 Rod Knock
Old 03-09-2013, 11:29 AM   #6
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 25,166, Level 95
Points: 25,166, Level: 95 Points: 25,166, Level: 95 Points: 25,166, Level: 95
Level Up 82% Completed
Forum Activity 100%
FF Reputation: 81 felixthecat Excellent Standing Member
Originally Posted by forddiesel1 View Post
Another question for those in the know. Do I have to pull the Balance Shaft to get to the bottom of the con-rods? If so it doesn't appear that balance shaft can be successfully reinstalled because it's timed. Therefore, if I am installing main and crank bearings a BSD is a pre-requisite right? I ask because although I like the idea on an extra quart of oil, I don't like the idea of finding surprises on a limited time/financial budget.
Yes you'll have to pull out the balance shaft's. You could possiblely get away w/ just the bearings. Theres no surprises of doing a bsd. Just be surprised of the weight of it. Less rotating mass & a 1.5 qtr of oil can't hurt. Don't forget the static mass also. 18-19 lbs.
felixthecat is offline
