Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - water cooling turbo?
Old 03-09-2013, 01:44 AM   #3
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
Points 6,652, Level 53
Points: 6,652, Level: 53 Points: 6,652, Level: 53 Points: 6,652, Level: 53
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 3 paulg127 Good Standing Member
I tried to tap lines that had some distance or hardware between the tap points to provide some flow (pressure differential) through the turbo. The 'turbo by garrett' site provided some good insight to the ideal angle the fittings shoule be at to provide maximum thermo siphon effect. http://www.turbobygarrett.com/turbob...il_water_lines
Of course with a bearing turbo, you probably don't need the H2O cooling...my e-bay crapper turdbo needs all the help it can get...
I'm on Hanford, you can swing by to check out the tap points.
paulg127 is offline
