I have been doing research and wanted to get forum's opinion regarding cat-back exhausts. From what I have gathered all exhausts manufacturers have increased the stock size pipe to 2.25 inch diameter pipe adding their muffler and an exhaust tip to top it off. I was wondering if you have these local Mexican muffler shops just install a 2.25 diameter pipe just from cat to muffler, would that make a difference. Why would these companies charge so much for their product if these local shops can meet their specs at a fraction of the cost.
Your opinion is highly regarded, thanks in advance.
Sent from my SAMSUNG-SGH-T989 using Xparent Cyan Tapatalk 2
The higher quality aftermarket kits use mandrel bent stainless steel tubing vs crush bent steel/ iron/ non stainless steel/ aluminized steel tubing that your local exhaust shop would usually use which constricts the flow at every bend and would be worse than stock.
If you can find a shop that has a mandrel bender and can use good quality stainless pipes it might be ok, but most just use the cheap tube benders that crush or crimp the pipe in the process.
In Vegas aluminized steel will likely last the life of the car, so paying for stainless might be pointless.
Enough 2.25" stainless to do the exhaust would cost close to $200, or more retail, plus $150 for the muffler. 2.5" Aluminized steel would be $50 plus $100 for the muffler. Add labor and you can probably still beat that $650 plus labor magnaflow cat-back price, get dual out if you want, and support your local working stiffs.
Mandrel bends are better, but 2.5" crush bends would suffice I would think, especially with the cat in front of it.
That being said shops with mandrels are not that hard to find, there is at least one here in SD, probably one in vegas as well.
If all your looking for is a different tone of noise= Why not just add a different muffler?
Sent from my SAMSUNG-SGH-T989 using Xparent Cyan FF Mobile
Crush bent or mandrel bent has negligible horsepower diff on a naturally aspirated car. As long as you keep the bends to a mild degree you'll get pretty much the same results for cheaper unless you are squeezing every bit of HP you can get then spend some money.
The shop near my home will do a 2.5 inch pipe from cat to muffler for $120. I intend to keep muffler for now. Is it worth the spend?
Related Threads
Focus Fanatics Forum
5.8M posts
189.1K members
Since 2003
