Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Steering wheel vibration AFTER a balance and rotation???):
Old 03-07-2013, 06:44 PM   #39
BlueFocusSE5
Fan#: 97166
What I Drive: 2002 Ford Focus
FF Reputation: 1 BlueFocusSE5 Good Standing Member
Originally Posted by katkrazy2007 View Post
No, unfortunately, I didn't know anything about getting a four wheel alignment -- I had never even heard of it before now ): And yes, I swapped off the mismatched tire for one of the same exact size and similar tread pattern.
Similar tread pattern, not the same tire brand, model and size? There are many more differences to tires than merely the tread pattern. If the tire isn't the exact same brand, model, size and speed rating, then the tires are not matched. Why didn't the auto center match the tires you have? The more you tell me about this place, the more I am seeing you are getting very poor advice from them, if not all out dishonest advice.
Check your receipt and tell me what you were charged for the supposed alignment. Performing a two-wheel/front wheel alignment with a vehicle that requires a four wheel alignment, (which your Focus does), is a total waste of money. The vehicle isn't properly aligned. It's worse than paying for a tune up with a four cylinder engine and only replacing two out of the four spark plugs.
If they have a four wheel alignment machine and they only performed a front wheel alignment, you need to go speak to the head manager with your receipt in hand and politely demand the proper four wheel alignment be completed. If they give you any grief, you can mention that if they don't do the proper job, that your next step will be to contact your State Attorney General's Office and your State Office of Consumer Affairs and do so! As a consumer, you have a lot of rights on your side when dealing with a dishonest/incompetent auto center!
I get so boiling angry when I see people getting ripped off for auto repairs!
-- B.F. Goodrich T/A Certified Tire Specialist
BlueFocusSE5 is offline
