Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Exhaust specs
Thread: Exhaust specs
Old 03-07-2013, 01:21 PM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 23,944, Level 94
Points: 23,944, Level: 94 Points: 23,944, Level: 94 Points: 23,944, Level: 94
Level Up 60% Completed
Forum Activity 100%
FF Reputation: 79 felixthecat Excellent Standing Member
Originally Posted by Artplata View Post
I have been doing research and wanted to get forum's opinion regarding cat-back exhausts. From what I have gathered all exhausts manufacturers have increased the stock size pipe to 2.25 inch diameter pipe adding their muffler and an exhaust tip to top it off. I was wondering if you have these local Mexican muffler shops just install a 2.25 diameter pipe just from cat to muffler, would that make a difference. Why would these companies charge so much for their product if these local shops can meet their specs at a fraction of the cost.
Your opinion is highly regarded, thanks in advance.
If all your looking for is a different tone of noise= Why not just add a different muffler?
Sent from my SAMSUNG-SGH-T989 using Xparent Cyan FF Mobile
The higher quality aftermarket kits use mandrel bent stainless steel tubing vs crush bent steel/ iron/ non stainless steel/ aluminized steel tubing that your local exhaust shop would usually use which constricts the flow at every bend and would be worse than stock.
If you can find a shop that has a mandrel bender and can use good quality stainless pipes it might be ok, but most just use the cheap tube benders that crush or crimp the pipe in the process.
^^^^^^^^^^^^^^^THIS^^^^^^^^^^^^^^^^^^^^^
Originally Posted by Sean05 View Post
my se sport had 2.25 piping in most of the exhaust....
^^^^^^^^^^^^^^^^^This is what you have^^^^^^^^^^^^^^^^^
Originally Posted by darkangelism View Post
fswerks is 2.5"
If you want to get a desent quality system, here you go. ^^^^^^^^^^^
felixthecat is offline
