Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Bad/Frozen VCT Gear? Miss drvin my baby plz help?
Old 03-05-2013, 11:47 AM   #3
lilfocusfreak
Fan#: 100585
What I Drive: 04 sonic blue svt
FF Reputation: 1 lilfocusfreak Good Standing Member
Thanks Tom... I will look into that today when I get off work... I hope its simple fix as so... but knowing my luck I doubt it... Was just weird because it only seems the belt is loose between the two cam gears like my vct is stuck towards the frnt bumper....If I remember correctly wouldnt the vct gear want to spring back towards the windsheild and take the slack out of the belt between the two gears? If the tensoiner is going bad n allowing the belt to slack, wouldnt it start to slide off the gears towards the pass fender.. Dealt with this when I did my timing tryin to get the belt tensioned right, too tight i thought moved belt towards engine, too loose made belt run towards fender part of pulley..,. My belt is still in the middle where I tensioned it too when I did my timing...
lilfocusfreak is offline
