Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Cleaning the EGR tube
Old 03-05-2013, 11:53 AM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 13,850, Level 76
Points: 13,850, Level: 76 Points: 13,850, Level: 76 Points: 13,850, Level: 76
Level Up 50% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
Time... let the tube soak. make sure you use a small enough pipe cleaner to go through the constrictor otherwise you may push gunk into it and end up clogging it.
have compressed air so you can force air through.
when installing use appropriate anti-seize so future removal is easy that nut becomes difficult to remove with the heat and thermal cycles it sees.
The tube should be fairly clean given how much actually is able to flow back into the intake.
Magus2727 is offline
